I'm on the search for some track day wheels. can someone confirm the PCD and required offset for a Plus 8? Its a 1988 model if that's important (and using a BTR axle).
Is the stud pattern shared witha ny other makes, i.e Ford?
Plus 8 wheel pcd and ET
Re: Plus 8 wheel pcd and ET
Mike, Don't know but Brian at Techniques / Chas at MogSport will no doubt be able to advise.
- Andy Green
If you need to buy some wheels then IMAGE 3 piece are the best and IMAGE have all the information (and lots of styles to choose)
Andy,
We are lambing at present, so i have an excuse for being up early
wot is your excuse?
wot is your excuse?
- Andy Green
Peter
I am in Dubai,4 hours time change
I think you will find that the Morgan +8 5 stud wheels have a PCD of 127mm am not sure of the inset/offset. I will have another dig through all my info papers, according to my records 127mm wheels were fitted to the following
Sherpa K2 & 2.8 Van - 14"
Rover SD1 - 14"
Austin Taxi - 16"
so not a lot of choice!!!
Rover SD1 - 14"
Austin Taxi - 16"
Morris / Austin 1800 (landcrab) had the same pcd I think
Thanks all, very helpfull and should help me sort my problem out.
