I'll be needing some tyres for my 4/4 soon, size 165/80 15. The options I can find so far are: Continental; Firestone; Michelin XZX; Kuhmo 758; Toyo 330.
I'm looking for something from List 1A and the use will be sprint, trackday and touring.
Can anyone recommend, advise me to avoid or suggest an alternative I may have missed?
Thanks, Simon
4/4 Tyres
- Simon Moore
- Richard Smith
tyres
Toyo Proxes T1R's seem a good option, many of us use them.
tyre pressures
I have invested in some Toyo proxes to replace my sticky Kumhos which are now dead. Any suggestions for cold pressures for sprints?
(They are 185x55x15)
- Richard Smith
pressures
This is something you will have to experiment with John. Basicallly, you need the tyre tread to stay flat on the tarmac, which usually involves increasing the pressures to keep the tyrewalls stiffer. I ran mine at around 30 psi. However with my current Yoko's, I have dropped the pressures to 20, which is surprisingly low. Another reason why we have a couple of practice runs in sprints!
tyre pressures
Thanks Richard- will I go as fast as you now?
see you at Curborough,
Simon Baines
I agree with Richard, tyre pressures differ from circuit to circuit, dependent upon how grippy the surface is, and therefore how much lateral force you apply to the tyre.
However, when I ran the +8 on Proxes' at the Goodwood Sprint, I ended up at a cold pressure of 28 psi, front and rear, although in your case, a lighter car may result in a lower cold pressure.
Start in the high twenties and work up and down from there.
