I have the following for sale came off my Zetec E ""black top" engine.
All have only covered 3500 miles
Twin 45 DCOE Weber carbs with allot trumpets, 5 progression holes to suit Zetec engine.
Twin DCOE inlet manifold.
4 X Webcon filters, fit on trumpets.
Weber twin cable throttle linkage.
Pair of Raceline 190 camshafts, made 189hp on the above carbs.
Raceline low profile, big wing, baffled, alloy sump.
Burton Power, hydraulic clutch slave cylinder for type 9 box, with extra spacers if I can find them.
Raceline lightened flywheel.
Heavy duty clutch, loads of life in it..
Kent cams timing belt, only used for 1 season.
MOCAL oil filter sandwich plate. 3/4 UNF.
Omex 200 series ECU and engine loom, with map for carbs and the cams listed above, gave 189 hp on multiple dinos.
Raceline alternator kit, alternator not included, just the fitting kit.
Spare 2.0 Zetec engine, came out of a Ford Mondeo, 78000 miles, I saw this running when it was in the car.
It would be good to sell as a "job lot" but may split.
Get in touch to discuss price £!?!
Cheers Jim (07886 074634)
Zetec engine parts for sale
Re: Zetec engine parts for sale
Now sold
