Door Lock
Door Lock
I have a problem with the Driverside door lock in my 2012 Plus 4 Supersport. The small black lever that is used to lock/unlock the door is stuck in the up or locked position, so consequently I cannot open the door from either outside or inside| Any knowledge or advise or suggestions would be much appreciated, thanks.
Re: Door Lock
leave it as it is
spring into the car as they did in days of yore
or in your case clamber in
in any case its an opportunity to get your leg over1
Re: Door Lock
Try a very large hammer.
Re: Door Lock
Two very admirable suggestions! Try those with the roof on!
Peter, could you send me a PM, I would like to speak to you, thanks.
Re: Door Lock
Success, and I didnt have to use a hammer, well not too much. Removed the door card, then the 4 chrome nuts, which allowed me to open the door with the lock still attached to the B post. Then I drilled out the 4 blind rivets on the back of the lock which exposed the latch mechanism. RESULT! Putting it all back together will be a lot simpler.
Re: Door Lock
Andrew , have pm'd you
my details also available on Morgan challenge rce section of this Forum, under Contact details
