Hi,
I have the original cast manifolds on my moss box +8 and the near side one has a crack around the rear port. I'm looking for advise on finding a replacement Are these available used / off what / part number??
I may consider tubular replacements but I quite like the single exhaust system and would ideally like to retain it. The left bank tube runs between the sump and the 'box and joins the right side before exiting on the right (near side) of the car. It's a LHD early '71 car.
Many thanks,
Jonathan
Moss Box +8 manifolds
- Phill Thomas
Re: Moss Box +8 manifolds
Jonathan, Tim Ayres did have a couple of cast manifolds off an injected 4.0L, no idea if they are suitable, give him a ring a New Elms.
Phill
Phill
Hi Jonathan
I recently had a cast iron manifold repaired by Cast Iron Welding Services of Coalville..
They did a superb job.......took about 10 days
Cheers.
Robin
Cheers.
Robin
Thanks guys, most helpful.
Jonathan
Jonathan
