Distributor problems 1982 Plus 8
Long time Morgan owner and former racer, Peter Binder has a 1982 Plus 8. The original electronic distributor failed and he replaced it with another new one.This has also failed and he wonders if anyone knows of a more modern and reliable unit he can fit?
Re: Distributor problems 1982 Plus 8
71 views and not an idea between you!
Luckily I have some better informed contacts and have resolved the problem myself!
Sorry for the delay Mary. The best aftermarket distributor I have found for a Plus 8 is the Mallory Unilite (not their Dual Point). All the information you need is here. http://www.gomog.com/allmorgan/MalloryUnilite.html At the moment, the best source in the UK is probably Real Steel.Mary Lindsay wrote:71 views and not an idea between you!
L.
